C4 Vs. C6 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2007, 11:39 AM
C4 Vs. C6
Ok, so i'm running a 351C in a 68 Mustang w/ 600+ horses and i was wondering which trany to use. I have the C4 already b/c it came behind my stock 1968 289. I didn't know whether to keep it and rebuild it or buy a car C6 and rebuild that.
Old 10-22-2007, 04:39 PM
Notorious's Avatar
Hot rodder, not street rodder!
I've heard of C4s that were built to take a lot of power, but obviously it wouldn't be cheap. The main advantage would be less weight overall and less parasitic power loss compared to a C6. But the C6 is already a damn tough unit to begin with and if it were me, I'd use the C6, modified to withstand your power level of course.
Old 10-22-2007, 04:49 PM
Go to fordmuscle.com they have info on the C4. A well built C4 will take about 900hp. They show all the mod's for improving the trans. including doing a roller conversion. TF
Old 10-22-2007, 05:53 PM
i would go with the c-6 make sure to get a p-code servo or an aftermarket servo and get the 5 clutch direct/reverse drum with the heavier tranny that just means you need more power
Ford 8.8 rear and C4 or C6 trans in 46 Ford... 46FordSuperDeluxe Transmission - Rearend 9 04-27-2007 05:59 AM
Ford "Y" Block and a later C4 or C6 Transmission RAW Transmission - Rearend 6 04-02-2006 08:01 PM
Will a Ford C4 shifter shaft fit into a C6 onebadmerc Transmission - Rearend 3 12-07-2004 06:22 PM
C6 specs versus C4 k2mooch Transmission - Rearend 2 05-19-2004 10:06 AM
C6 or C4 akm Transmission - Rearend 2 04-09-2004 02:26 AM
