c5 corvette vs. ls1 rear brake calipers - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2008, 01:27 AM
FIREBIRDTONY's Avatar
Last journal entry: the rear body panel
are the rear calipers on the c5 and ls1 interchangeable? will i need the ls1 abutments in order to mount the c5 calipers on my camaro?
this is my delima.. i am puting disc brakes on my 68 bird. i have c5 corvette discs up front and want discs on the rear also.
i coped a great pair of rear c5 calipers for under 80 bucks complete. i can get a pair of rear brakets to mount my c5 on the 10 bolt rear end, but they dont allow for the parking brakes.
after i bought them i found out that 95 ls1 model rear brakes was a direct bolt on with the parking brakes.
after some research i found out that the c5 calipers were an upgrade swap on the ls1 but i dont know if you use the ls1 abutments or the c5 abutments in order for the swap to work.
any help would be great....
Old 04-06-2008, 04:22 PM
My guess would be that you would need the C5 abutments with the C5 calipers.
Where can I fnd a disc brake kit for jaguar rear end Larry Tyner Suspension - Brakes - Steering 8 01-08-2010 02:50 PM
Rear Disc Brake Pad Replacement ccarccrazy Suspension - Brakes - Steering 3 01-13-2007 08:59 PM
rear brake line? tombo615 Suspension - Brakes - Steering 4 07-02-2006 08:24 PM
Ever had rear brake drums that refuse to come off? JunkYardFrog Suspension - Brakes - Steering 23 01-12-2003 12:13 PM
FWD 3800 into rear - C5 Vette susp? hotrod_tommy Transmission - Rearend 2 03-24-2002 05:03 PM
