C6 band adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2012, 02:54 PM
C6 band adjustment
I'm messing with the band adjustment. It isn't right, having a heck of a time finding someone who knows enough to answer my question..
When torqued down to 10 ft lbs then backed of 1.5 turns it puts the nut to the point where if I turned it in just a bit I can feel a tiny bit of pressure on the bolt.. As is there isn't any pressure.. Is the bolt suppose to be that loose? Or should the band have a tiny bit of pressure on it??
Greg
Old 01-16-2012, 05:03 PM
Crosley's Avatar
Wiki Edits: 1659
tighten the band stud to 75 inch pounds, back out 1.25 turns will work well.
horizontal band saw freeskier Garage - Tools 17 03-17-2011 12:58 AM
Wide band or narrow band A/F...? staleg Engine 6 08-12-2008 02:10 PM
best band 2003 Audioslave. best band 2004 Velvet Revolver bullheimer Hotrodders' Lounge 21 02-02-2005 09:43 PM
Band adjustment question...... BstMech Transmission - Rearend 2 04-24-2004 11:57 PM
283 Power Band? icegnome Engine 4 12-02-2002 08:22 PM
