C6 broken bellhousing bolt hole.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2011, 09:28 PM
Wiki Edits: 31
Pulled my 460 apart from the C6.. upon pulling a bolt I had used for the chain out, I noticed the trans case had broken away from the bolt. Not real bad or anything but it is busted out and can't be peiced back togther. Can I use some epoxy putty and re- form the case bolt hole?, with some good lock tite and a larger washer when it comes time to put it togther again?
Old 08-17-2011, 10:18 PM
toomanyoldFords's Avatar
You still have 5 others. I would not worry about it.
Cracked steam hole going to bolt hole projectman69 Engine 4 11-10-2010 06:54 AM
350 starter mount bolt hole broken... oldschool70k5 Engine 2 03-25-2010 11:55 AM
Broken Bolt in a bellhousing CHEVY. monzter Transmission - Rearend 3 11-19-2008 09:29 PM
TH350 Bellhousing Broken BrandOmatic Transmission - Rearend 6 09-28-2006 09:29 PM
engine bolt hole to bellhousing is broken, is it ok? 66StangBoy Engine 6 11-06-2002 05:25 PM
