C6 experts - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2004, 12:16 PM
Last journal entry: PICTURE TEST
C6 experts
Ok i did a stupid human trick.... When i took the valve body apart I got the converter check valve assembly spring. And the throttle pressure check ball spring seperated from the correct spot. I think the longer with more coils spring belongs in the converter check valve assembly,,, Is this correct???? My tech book does not show a clear answer to this......
thanks , Keith
Old 12-02-2004, 03:46 PM
stu stu is offline
Thumbs up
aaaaaaaaaaaayyyyyyyyuuuuup.
That be the place.
Don't care for this expert tag though.
X is an unknown factor and a spurt is a drip under pressure.
But then you could be right.
Old 12-02-2004, 03:58 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Hmmm . . . I always heard it as "ex" is old-tech and "xpret" is a spurt. Thus "expert" is a 'has-been drip under pressure'.
Old 12-02-2004, 06:39 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
I have wondered for years when I became a transmission technician.
I still tell people I am just a dumb mechanic that works on cars for some reason
Old 12-02-2004, 06:44 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I've self titled myself as a "po' dumb schmuck in a pick'em-up truck" before.
Old 12-03-2004, 05:41 AM
thanks guys
Sorry about the expert word........
I always tell people that i am a life student in the school of hard knocks!!!
Keith
