Does anyone know where to get a governor recalibration kit for a C6? i bought one for my TH400 from summit but cant seem to find any for my Ford, Thanks.
You can also adjust shift timing under light throttle via the vacuum modulator 2 methods :
Usual method of adjustable pre-load on spring inside via the hose nipple. Screw inside this nipple. Crank in ( clockwise) to increase tension = later shift
Also , the pin between the modulator and the valve inside the trans.... longer pin = later , firmer shifts. Shorter pin = softer , earlier shifts. Change length no more than 1/16 inch at a time for testing
buy a shift kit for the valve body. easy to install,then play withe the modulater,they ar not all adjuatable,then the throttle pressur rod adjust so you hit the stop when carb linkage hits full throttle.cliff
When i adjusted the shift points in my th400 it was trial and error with different weights and springs which were easily accessible on the side of the trans. From everything i have read and been told the Governor on the c6 is on the tail shaft of the trans. The c6 im working on is in a bronco with a transfer case bolted to the back of it. Is there no way to access the Governor with out unbolting the transfer case? or do i have to unbolt the trans and transfer case every time i want to make an adjustment? seems like a real pain considering it might take a couple tries to get it to shift where i want.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
