c6 kickdown linkage - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2008, 03:59 PM
billlt583's Avatar
c6 kickdown linkage
Hi guys and gals
Looking for diagram for kickdown linkage and adjustments. Am working on 69 mach 1 with 351c and c6
Thanks dudes & dudettes
Old 09-12-2008, 08:38 PM
woodz428's Avatar
Troll Hunter
I don't have a diagram that is easy to post, however it is important to remember that the carb needs the appropriate pieces too. The linkage is a simple piece of tubing that is bent to clear the engine/trans and attach to the kickdown lever. It has a hole on either end. The adjustment is straight forward and done at the aforementioned carb piece. To adjust you open the carb fully and push the acrb kickdown lever back until it has pushed the lever fully, adjust the screw out to the carb lever that the rod is attached to. That's it. It is different than an AOD pressure linkage.
Old 09-13-2008, 07:02 AM
cboy's Avatar
Last journal entry: Finished
Originally Posted by woodz428
To adjust you open the carb fully and push the acrb kickdown lever back until it has pushed the lever fully....
Just for clarification...you push the kickdown lever back until it has pushed WHAT lever fully? The attachment lever on the transmission?
Always learning...and sharing what I've learned.
kickdown linkage inkd1971 Transmission - Rearend 1 09-02-2006 06:43 PM
C6 Linkage wows "70" Cougar Transmission - Rearend 19 11-24-2005 07:34 PM
68 mustang kickdown linkage fla68rustang Transmission - Rearend 0 08-09-2005 07:33 PM
kickdown linkage kidmopar66 Transmission - Rearend 0 07-06-2004 08:08 PM
Kickdown Linkage help? dadeeoo Transmission - Rearend 0 05-24-2004 01:26 PM
