C6 Linkage wows - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-23-2005, 05:44 PM
"70" Cougar's Avatar
Meat-Head Extroidenaire
sweet .. thanks guys ! Well i appreciate all the help and hey saabstorey thanks for the offer but the trany probably isn't worth the shipping from your place to mine. but hey if you have the space keep it for someone else or yourself. hey cliff tate umm ... how much would it take ($) to alleviate this burden off your shoulders .. im not greedy, just need one. As long as the tranny housing is perfect.. with out cracks .. i plan on a total over haul so mileage doesn't matter . A shop called " L & D transmission " quoted me about $100.00 for not having one to start with.. plus they will not give me any money or take any off for the FMX i already have. oh also there including the shifter linkage. im not sure if everyone always does.
thanks
bill
  #17 (permalink)
Old 11-24-2005, 09:05 AM
thanks
i paid 100 @ for mine would sell for same but ther is no torkconverter would use a rebuilt one to sute your engine, cliff. email me if you want it ct1940@telus.net
bill
the linkag is ther tailhousing has new bushing and seal
  #18 (permalink)
Old 11-24-2005, 09:39 AM
Max Keith's Avatar
C-6 blues
All 302/5.0, 351W/5.8, and 351Clevelands use the same bellhousing bolt pattern. The transmissions from any of those engines can be bolted to any of the others.
C-6's came with heavy duty 302 packages, in pickups, and behind most 351W and 351C engines, unless it was equiped with an FMX transmission.
I guess the question I would have is why go with a C-6, when the C-4 is quite capable of doing the job, is a lot lighter in weight, and doesnt steal as much power as a C-6, not to mention more plentiful, and less exspensive.
  #19 (permalink)
Old 11-24-2005, 06:17 PM
well for some reason I've told myself that i think a C6 will hold more horse and torque then the C4 . Now im not saying im right but I've pretty much talked myself in to it.
  #20 (permalink)
Old 11-24-2005, 07:34 PM
Max Keith's Avatar
C-4 vs C-6
Yes, in fact the C-6 will take more power than will the C-4, however, C-4's have been known to take on 600 hp in stock trim and survive it, for a long time. The biggest detriment6 to either of those transmissions, be it the C-4 or C-6 are doing line loads on them for dragracing (harmful to any auto trans as it generates extreme amounts of heat, burning the fluid) and doing manual 1-2 shifts, with a stock valve body. The reason this is damaging is because when you shift manually, the transmission wants to shift up first, then back to 2. According to one article I read several years ago, put out by one of the Transmissoin gurus, that you reduce the life of these transmissions by 2 shifts every time you do one manual shift from 1 to 2. IF you like to shift your own gears, then I would suggest you get a shift kit, as it will alter the plumbing to eliminate the weak point of manual shifts with the stock valve body.
As a point of trivia, Ford made a bellhousing for the M blocks in the mid 70's that would bolt the C-4 to them. Vertually every one of those bellhousings that have ever wound up in a junk yard or garage or whatever, has been scavanged up for guys runnning 429's and 460's in dragracing. If a C-4 (worke over of course) will take that kind of beating, it should stand up well to a street engine.
The M (351/400)block and the Lima (429/460) block use the same bellhousing bolt pattern.
In the case of them using C-4's behind the Lima block, its the bellhousing that tend to crack and break after a period of time due to the extreme torque, not the transmission itself.
Progressive Linkage On Blower Carbs Setup? 5-7heaven Engine 6 10-07-2007 10:30 AM
68 mustang kickdown linkage fla68rustang Transmission - Rearend 0 08-09-2005 07:33 PM
Firebird and Camaro clutch linkage BanditT/A Transmission - Rearend 1 10-25-2004 09:13 PM
C6 specs versus C4 k2mooch Transmission - Rearend 2 05-19-2004 10:06 AM
clutch linkage!!? chevyelc81 Transmission - Rearend 11 08-01-2002 06:46 AM
