C6 pressure port? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2014, 07:49 PM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: power tour
C6 pressure port?
Do C6 transmissions have pressure ports? Looking for some where to install a temp gauge..
Old 02-03-2014, 08:13 PM
temp gauge
the only place is in the pan,as oil from cooler goes ther so that is the logical spot. remove pan and have a fiting brased i,depending on the size of capilery tube
Old 02-03-2014, 08:28 PM
Hwyhogg's Avatar
Figured as much....will be using deep aluminum pan...will have to find a shop to do it. maybe I'll find a wy to use a fitting in plug hole...
Old 02-03-2014, 08:33 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Yes they do have a port. On drivers side, above shift linkage shaft
Old 02-08-2014, 02:43 PM
Hwyhogg's Avatar
Thanks again guys
Fuel Pressure Port aisr Engine 1 02-15-2011 10:09 PM
BBC Oil Pressure Port - Which One To Use S10 Racer Engine 6 01-24-2009 08:59 PM
700R4 4gear pressure port 42S10 Transmission - Rearend 2 05-24-2007 10:42 AM
Oil pressure port on 351M cboy Engine 8 06-14-2005 01:15 PM
AOD throttle valve pressure port mustang66maniac Transmission - Rearend 2 01-08-2003 02:44 PM
