Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - C6 trans noise at idle
Old 11-06-2004, 12:31 PM
tm454 tm454 is offline
Tazz
Tranny noise.....
OK..I know this about a torque conveyor..if its bad the car won't move. If it was a GM trans I would say the front pump is going but on a Ford I don't know. I use Sea Foam from NAPA to help with the simpler trans problems...try some and see if your noise goes away...you will have to drain a quart of fluid off the trans as to not ovetfill your trans. Just loosen the bolts on the tranny pan and drop one end and catch the fluid...the environmental thing...don't ya know!! Don't let the trans fluid drain down into the gravel in your dirveway....
Tazz
Rat Rods Rule!
