Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - C6 trans noise at idle
Old 11-06-2004, 03:14 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Cool
could be the converter , could be the pump.
Could be the pump having to work hard to build pressure if you have a leak internally.
I can't be much help with out hearing the noise
