Originally Posted by lil-vulky
which of these hoses are ment to be on the manifold vacum? number 1 or 2? and is the one not need ok left as it is or should i block it with a screw or something?
#2 gets the manifold vacuum. Leave #1 open to the air. You can use a piece of vacuum hose on it routed so nothing will get in it. Be sure it will hold vacuum. And that there is no ATF inside the vacuum hose or modulator port. If there is, it could be from the diaphragm leaking.
FWIW I am seeing elsewhere where people run w/o the kick down w/o problems, so I don't know what's up w/that. One way to get most of the needed parts is to get a
Lokar kit, but it's pricy. It includes the bracket arm that goes to the tranny. I didn't look to see if there were other kits from the different vendors. The carb needs a bracket, too unless it's already on the carb. Holley sells them IIRC.
I don't think the shift arm you have is for the floor shifter. I seem to remember mine looking a lot like yours, and my Torino came w/a column shifter. At least until I changed it for a B&M floor shifter.
