Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - C6 trans setup linkage and stuff?
  #22 (permalink)
Old 11-13-2012, 05:49 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by lil-vulky View Post
have just noticed a bolt missing just above the modulator, in the black circle that is where the modulator thingy goes and in the red circle is a threaded hole not sure what its for? it doesnt leak trans fluid or anything and has clean thread
sorry about the angle of the picture, if you tilt your head to the right its the right way
red circle is return line from cooler for trans oil,
Modulator with dual vacuum lines: one line(center) is main manifold vacuum... outer vacuum line would be hooked to ported vacuum source.
The two lines work together for controlling shifts. Ported vacuum would help the trans to down shift sooner in a situation like turns the vehicle did not stop fully at.
