Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - C6 trans setup linkage and stuff?
  #23 (permalink)
Old 11-13-2012, 05:59 PM
lil-vulky lil-vulky is offline
ohhh i see, sooo ummm about this return line for the cooler, do i need it? if so where do i get and put a trans cooler . . . ahh can i just put a bolt in the hole and forget about a trans cooler? will try get a 1 hose modulator but if i can only get a 2 one, where abouts is a ported vacum? i know where to stick the main manifold vacum hose but not sure where a ported one is ?
also the trans is hooked upto the engine and iv had the engine going abit because had to get that all sorted . . . is the trans stuffed seen i had the engine running with all this stuff missing not attached etc. just woundering might be easier looking for a whole new trans not that i have money lol if there is still a chance my trans is fine ill try get all the bits sorted will be a hell of alot cheaper its like $1500+ NZD for a 2nd hand trans in good knows what condition.
