C6 Transmission Shift link & Kickdown - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2012, 01:45 PM
My application is a 72 mustang floor shift. I put a column shift c6 in and the shift link will not work. I also see no lever on the trans either to hook up my kickdown link. I heard you can go through the pan and adjust the shift lever? Or do I need a whole new setup off an floor shift c6 including the kickdown lever inside the trans? I picture of how it should look would be great!!!!! I only have one lever inside the trans pointing down and this is all.
Old 01-05-2012, 06:03 PM
tnsmith10's Avatar
when will it rain???
when it comes to the earlier ford transmissions, it was common that the cars linkage went up and the trucks went down on manual arm position. yes, you can drop the pan and flip the arm but, more than likely the arm is going to be too long and will throw the detents off.
as far as the kickdown goes, it should be just like the c-4 with a smaller rod going through the manual arm. if it has no provisions for it that would make me believe that you dont have a c-6. sounds more like a AODE/4R70W or a E4OD.
Old 01-06-2012, 01:19 PM
Ill post a picture of what im working with as far as the shifter on the trans. You had me thinking it may be an aod but the pan is different. Ill report back
TH350 transmission oil level at kickdown cable seal Elder Rodder Transmission - Rearend 3 11-13-2010 07:22 PM
Eliminating the kickdown cable from the th350 transmission Richard Locke Transmission - Rearend 16 01-31-2009 10:43 AM
727 shift link advice... 68RATVT Transmission - Rearend 3 03-23-2007 05:37 PM
transmission kickdown malibuman66 Transmission - Rearend 9 07-07-2004 02:05 PM
turbo 350 transmission kickdown stuck 1957GMC100 Transmission - Rearend 0 12-21-2003 04:48 PM
