c6 will it work? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2006, 12:33 AM
c6 will it work?
i recently bought a 390 motor and a c6 transmission for $150 at a swap meet will the c6 mount to the 390 and if so what will i need to do accomplish it?
Old 04-19-2006, 12:52 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
yes, it will fit, you just need the proper bellhousing and flexplate if the 390 doesn't already have one.
Old 04-19-2006, 07:06 AM
tnsmith10's Avatar
when will it rain???
the c-6 bellhousing is part of the case., its not like a c-4 where its a bolt on... its got to be a 390 case., it'll be rounded at the top, and it'll have 3 holes for the starter. also, the converter will have a short pilot. different than most c-6 converters
Old 04-19-2006, 10:38 PM
onebadmerc's Avatar
I need a bucket of arc sparks
Watch out for those FMXs, they put alot of them behind FE engines. C6s are two piece case, no removable bell housing. The FMX is a 3 piece case, removable bell housing center case and removable tailshaft case. The center case of a FMX should be cast iron. I also have seen a few C4's behind FE engines, but not many. They also have a three piece case but the center part is cast aluminum.
Old 04-20-2006, 12:55 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
c6 will it work?
raymrajak put one behind his 390/428 block. If he doesn't see this PM him for help. Here's his thread:
1964 Ford Galaxie country sedan wagon
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
"a little over" turns into $4500 over for paint job bullheimer Body - Exterior 128 02-06-2006 08:57 AM
Work gripe. Share yours? killerformula Hotrodders' Lounge 25 11-22-2004 04:01 PM
Work. coldknock Hotrodders' Lounge 6 11-21-2004 04:57 PM
Stuff I work on at work :) esears Hotrodders' Lounge 6 09-29-2003 01:08 PM
Ever work on the impossible? johnsongrass1 Hotrodders' Lounge 16 08-20-2003 01:59 PM
