You won't get caught. There's no reason to get caught unless you tell the smog tech you replaced the original engine with an older engine. Don't do that! If the induction and exhaust systems are the same as original, there're no power adders and the car's original smog system is present and functional, you're good to go.
If you do have aftermarket stuff, make sure you have the proper EO numbers because you WILL be sent to a BAR ref and everything I said in my previous post will be checked. |
Smog equipment
Hi, all--
I found this thread and I had a question for those far more experienced than I. I'm a CA resident, and I'm looking at a used car that's had ALL of the relevant emissions equipment removed (it's an '84 Camaro V8)--cat, EGR, vapor canister--everything was removed when the carb was changed. Apparently the owner had a smog guy in his back pocket, but now needs to sell the car. Presuming that all of the parts are actually available, how hard is it going to be to purchase all of the relevant items, and then re-install them? I'm a plugs-and-oil guy, not much beyond that point, and I don't want to get involved in a project that will cost me more than the price of the car. Thanks for the information-any advice will help! |
If it were me, I'd move on! '84 Camaros are a dime a dozen. It's possible to scour the junkyards and collect everything you'd need but you'd have to have a working knowledge of the smog and fuel systems of those cars, not to mention a very detailed knowledge of auto mechanics in general. No offense, but as a self described 'plugs and oil guy', I'd look elsewhere.
In terms of mechanical complexity, I've changed alternators on a few of my cars, done belt replacements, changed valve covers, that kind of thing. Swapping a crankshaft would be beyond me (at least without some help), but I understand the basics and can follow a manual with the best of 'em. So I'm not completely lost, and I like doing the work, but I've gotten in over my head a few times and I'm not looking to repeat the experience. Ultimately, I guess I'm asking if I had to do the work to replace every piece of smog equipment that should have been there, about what would I be looking at in terms of time and parts? Is there a list somewhere that I could use to generate a worst-case scenario? I already know that the exhaust headers need to be swapped out (within my skill level), the tailpipe needs to be cut for a cat (will pay somebody else to do that), and the replacement Edelbrock needs to be tuned (also something I can do). Is the under-hood stuff a four-to-six hour job for a reasonable mechanic (which I would multiply by 3, that seems to be about the speed I go at), or a nightmare of a teardown? Again, thanks for the time, and the advice is very much appreciated. Matt |
esetially all you need to do is find a camaro that already has all the smog stuff and sit it right next to yours if you hav a buddy that has one or make a new friend that has one then go down to the salvage yard of your choice and buy all the parts you need its not to complicated its parts on the outside of the engine and vacuum hoses its on a scale of 1-10 id put it at 6 cause you have to know what you need and sometimes the parts are hard to find
so I have a 1983 buick regal the came with a v6 231 engine. i want to put a silverado 4.8 or 5.4 chevy silverado engine in it. is that legal? chevy makes buick right??
Unless the Regal came with a small block V8 (and I don't think they did), you'll be going to a BAR ref and they won't pass you.
They came with either the Chevy 305 5.0 or the Pontiac 307 5.0
By the way, the 307 was an Oldsmobile motor, not a Pontiac. The Pontiac was a 301. |
The Cal ARB and the BAR are acronyms for the Third Reich reincarnated. No appeals, no break and pay up or take it out of the state. Cruel but in typical state government fashion it is theor way of saying we really aren't intersted in clean air. We just want your money. Now when I do some swaps I register them to an address I have in another state where the registration fees are a small number compared to the $300. or so bucks this state wants.
Normbc9 |
| Valve Lash adjustment | hiball | Engine | 36 | 05-11-2009 10:12 AM |
| smog legal swaps | motorheadfred | Engine | 4 | 07-28-2008 03:41 AM |
| smog, smog, smog....CA smog , failed. | jakeslim | Engine | 12 | 08-20-2005 11:59 AM |
| Ca. Smog issues w/new EFI engine install | Bryan Munday | Engine | 0 | 01-27-2004 04:02 PM |
| cam, rockers and general engine questions | bildo95 | Engine | 6 | 07-15-2002 03:34 AM |
