Cab Corners For A 1950 International 1/2 ton PU - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2003, 01:48 PM
Post Cab Corners For A 1950 International 1/2 ton PU
Does anyone have/know where I can get two cab corners for a 1950 International 1/2 ton pickup? If so,,,, what $$$$$ range? THANKS IN ADVANCE........
Old 01-06-2003, 08:45 PM
bullheimer's Avatar
NEVER use credit cards!
Post
yes, but what kind of vette are you building that takes truck cab corners?
on second glance, i thought you said chevy, so the answer to your question is "no". and good luck finding them.
[ January 06, 2003: Message edited by: bullheimer ]</p>
Old 01-06-2003, 09:37 PM
Mr.56Chevy's Avatar
Post
I dont bu tif you find out where outside this board could PM me. My friend is looking for patch panels for his 55' International. Thanks.
Old 01-07-2003, 05:59 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Of course they make 50s Chevy and Ford corners. You might look at all those and find the one closest to the International. Then if you are fairly good with an anvil and ball peen hammer (or body tools if you got 'em)you might be able to reshape them to fit.
Old 01-07-2003, 06:14 AM
Post
Willys36 has the right idea. Make a template of posterboard of the curvatures of the bottom corners of your cab, then check it against a Ford (48-56 probably) or Chevy (47-55 1st). If they are close you can certainly modify them, you'll just need the tools and the welding skill. If you do't have it your local quality bodyshop should have someone who can handle the job reasonably.
Best of luck!
I love technology.
