Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cab dimensions
Thread: cab dimensions
Old 12-14-2004, 11:15 AM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
taco,
One method I use for getting all the rough dimensions is to find a plastic model of the car/year you are building and then simply apply the scale to the measurements you take off the model. Not perfect, but it will get you close. For $8-$10 bucks you can get virtually any dimension you need for any body part. I'm not sure I've ever seen a model of the '31 pickup but you should be able to lay your hands on a '30 or '32.
Combined with MK's frame dimensions (above) you should be in business.
Dewey
Always learning...and sharing what I've learned.
