Cab dolly for 47-54 chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2006, 10:38 AM
Am wondering if anyone has a cab dolly design with blueprints for the AD chevy trucks. Wanting to remove the cab from the frame due to space limitations but need something to support the cab in its natural state. Looking for a dolly design that allows easy movement of cab but still provides good strength for when I start cutting it up to do cab corners etc.
Thanks...Eric
Old 06-18-2006, 12:20 PM
shine's Avatar
Last journal entry: some progress
my body dollies are made from thin wall tubing. i cut a 6' piece and 2 4' pieces. 6 in the middle , 4 ' on ends. on each corner i weld a 12'' upright. to these i bolt 2x6 's. 8 ' for the car dolly and 4 ft for the truck. the truck dolly is only 4 ' long. i use good wheels for them as the cheaper ones don't last.
Old 06-19-2006, 08:27 AM
Eric, pull the cab and leave to doors on or brace it up so it doesn't flex, then build yourself some drop down legs that will bolt to the body mount locations, box the legs around the perimeter and add some angles so it can't flex and add the wheels. Having it bolt on will add to the rigidity.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
New '48 Chevy Truck seen in Classic Trucks Turkey Hotrodders' Lounge 4 11-28-2005 07:09 PM
New with old 1929 Chevy truck Rockafellow Introduce Yourself 2 08-17-2005 12:47 PM
Chevy Truck Chopped top 7 inches... :) bg Hotrodders' Lounge 11 08-30-2004 04:17 PM
Small Chevy car wheel to fit Chevy Truck musky2 Transmission - Rearend 4 03-16-2004 08:12 AM
