Bleeded system and now it seems worse. (Front end jacked higher when bleed) I have mitchel on demand, hayne and chilton books. Im trying not to rebuild the system again for something that might be a 20 min fix im overlooking. New water pump, new t-STAT, new heater core, radiator just about a year old with no leaks, 50/50 mix im running, and I have 2 options on t-stats from autozone 160 and 180, im running 180. If it sits while running its warm at best but if Im driving then its cold. Double fans set to come on at 210. And my radiator is capless, everything is added in resivour tank. Levels or capped off
