Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cabin Sandblaster fix!!
Old 01-22-2011, 08:57 PM
azlo azlo is offline
This is what the insert looks like after grinding it.
Installed the insert back in,,, and now u see the extra space. (allen wrench pointing at the insert.)
Put everything back together. What a diffrence!! I even lowered the psi to 80. And I even took all restrictions from the media feed hose, ( in other forums it is suggested to plug or restrict the media feed hose so you can prevent clogging or the surging effect.). SO now at full throttle I get a constant stream of media!! This is beautiful man!
This would usually take 40mins. It took 15 at most. I am one happy camper. I might even see if i can improove on this but it works just fine.
