-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Cabin Sandblaster fix!! (http://www.hotrodders.com/forum/cabin-sandblaster-fix-191213.html)
azlo 01-22-2011 07:56 PM
As some of you know I have the Harbor Freight sandblaster. Everybody has had problems with the cabin sandblasters. But after messing with it all day, i figured it out!! Let me explain.... this is the type of gun I have.
http://i777.photobucket.com/albums/y.../MAH007741.jpg
and black Diamond for media from Northern Tool. I was blasting with the gun upside down to see if it would make a diffrence when I realise that the media wouldnt get sucked. I took the hose off and the media would just sit here (see pic) when the trigger aT FULL blast (and gun upside down).
http://i777.photobucket.com/albums/y.../MAH007742.jpg
Media was stuck. Of course this very course media, but I also used fine glass beads and it was doing the same. So i took the end of the gun apart.
http://i777.photobucket.com/albums/y.../MAH007745.jpg
Took the ceramic end out.
http://i777.photobucket.com/albums/y.../MAH007747.jpg
Inside the gun is this insert.
http://i777.photobucket.com/albums/y...MAH0077413.jpg
This insert is part of the air feed passage and it meets with the suction passage where vacuum is created. U see where the allen wrench hits the insert in the gun...
http://i777.photobucket.com/albums/y...MAH0077410.jpg
Well the media would get clogged there. For some reason course or fine media would get stuck here. So,,, I took the insert & grinded it to give more passage without loosing vacuum.
azlo 01-22-2011 07:57 PM
This is what the insert looks like after grinding it.
http://i777.photobucket.com/albums/y...MAH0077414.jpg
http://i777.photobucket.com/albums/y...MAH0077411.jpg
Installed the insert back in,,, and now u see the extra space. (allen wrench pointing at the insert.)
http://i777.photobucket.com/albums/y...MAH0077416.jpg
Put everything back together. What a diffrence!! I even lowered the psi to 80. And I even took all restrictions from the media feed hose, ( in other forums it is suggested to plug or restrict the media feed hose so you can prevent clogging or the surging effect.). SO now at full throttle I get a constant stream of media!! This is beautiful man!
http://i777.photobucket.com/albums/y.../MAH007751.jpg
This would usually take 40mins. It took 15 at most. I am one happy camper. I might even see if i can improove on this but it works just fine.
matts37chev 01-22-2011 08:31 PM
is that the gun that came with the cabinet?
azlo 01-22-2011 08:33 PM
u know I heard people said they had diffrent guns with HF cabinets.
matts37chev 01-22-2011 08:44 PM
i dont have a cabinet, i just use a siphon blaster, out in the middle of the driveway with a bucket of screened sand i get from work
and its tough to use when its raining. plus i have to keep getting more sand
i've always wanted one, but never hear great stuff about them
you may have just changed that :D
boatbob2 01-23-2011 02:51 PM
Sandblasting.
Hi,i use a pressure blaster,before i start,i put a large blue tarp,half on the ground,the upper ends of the other half,i tie to 2 seperate trees (i live in the country) then when i run low on sand,i recycle the used sand by running it through a large funnel with a piece of screen stretched over it,to strain out rust or paint particles,i can USUALLY use the same sand 3 times.
pepi 01-23-2011 04:43 PM
Good fix, well done. I love these types of little tricks, cause they will make an almost tool work like a tool.
I have done the same type of thing with a Northern electric ban saw, little refinements make things so much nicer. Keep up the good work over there.
azlo 02-06-2011 06:06 PM
For the some of u thats asking if this sandblast mod works, well heres a vid.
U tell me if it works.
http://i777.photobucket.com/albums/y...xport_x264.jpg
Love the mods.
This is glass beads by the way.
matts37chev 02-06-2011 06:35 PM
looks like it works great :thumbup:
you just need three hands now and it would be even better :P
hookedup 02-06-2011 07:08 PM
Ill have to remember that with that gun. I had trouble with mine and was givin a differnt gun. The tips wear out sooo fast! I go thru many( I use my cabinet alot!) tips all the time, now i make new ones on my lil lathe out of steel. They dont last long so i make up 10 at a time. If you experiment with pressure and tip hole size, you'll find a happy spot it works best.
trees 02-07-2011 07:26 AM
Thanks for the post!! My son bought the same unit and I do not have very good luck with it. My son does better because he turned the pressure down!! Old dog would never consider that. I will take a look at the nozzle the next time it does not want to work for me and play with your mod.
Trees
