This is what the insert looks like after grinding it.
![]() ![]() Installed the insert back in,,, and now u see the extra space. (allen wrench pointing at the insert.) ![]() Put everything back together. What a diffrence!! I even lowered the psi to 80. And I even took all restrictions from the media feed hose, ( in other forums it is suggested to plug or restrict the media feed hose so you can prevent clogging or the surging effect.). SO now at full throttle I get a constant stream of media!! This is beautiful man! ![]() This would usually take 40mins. It took 15 at most. I am one happy camper. I might even see if i can improove on this but it works just fine. |
is that the gun that came with the cabinet?
i dont have a cabinet, i just use a siphon blaster, out in the middle of the driveway with a bucket of screened sand i get from work
and its tough to use when its raining. plus i have to keep getting more sand i've always wanted one, but never hear great stuff about them you may have just changed that
Sandblasting.
Hi,i use a pressure blaster,before i start,i put a large blue tarp,half on the ground,the upper ends of the other half,i tie to 2 seperate trees (i live in the country) then when i run low on sand,i recycle the used sand by running it through a large funnel with a piece of screen stretched over it,to strain out rust or paint particles,i can USUALLY use the same sand 3 times.
Good fix, well done. I love these types of little tricks, cause they will make an almost tool work like a tool.
I have done the same type of thing with a Northern electric ban saw, little refinements make things so much nicer. Keep up the good work over there. |
looks like it works great
you just need three hands now and it would be even better
Ill have to remember that with that gun. I had trouble with mine and was givin a differnt gun. The tips wear out sooo fast! I go thru many( I use my cabinet alot!) tips all the time, now i make new ones on my lil lathe out of steel. They dont last long so i make up 10 at a time. If you experiment with pressure and tip hole size, you'll find a happy spot it works best.
Thanks for the post!! My son bought the same unit and I do not have very good luck with it. My son does better because he turned the pressure down!! Old dog would never consider that. I will take a look at the nozzle the next time it does not want to work for me and play with your mod.
Trees |
| Recent Garage - Tools posts with photos |
| Cabin air filter location...help | 302 Z28 | General Rodding Tech | 4 | 07-06-2010 09:09 AM |
| Cabin Air Filter Video | ema | Electrical | 0 | 11-27-2009 04:27 PM |
| cabin fever | steve t | Hotrodders' Lounge | 2 | 12-18-2005 06:04 PM |
| Sleepy Bear Cabin Rentals | cseigler | Introduce Yourself | 0 | 11-06-2005 07:58 AM |
| Cabin fever | 4doorjoe | Hotrodders' Lounge | 8 | 02-11-2003 02:20 PM |
