cable to electronic? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2011, 08:27 PM
day day is offline
i have a 94 chevy c1500. i just put a 1980 350 small block in it with a 350 turbo tranny. is there any one who make a adapter to connect the cable drive speedo to a electronic speedo?
Old 06-08-2011, 03:59 AM
SSedan64's Avatar
Check here>> http://www.transmissioncenter.net/sp...____va.htm#350 look at the 40-Pulse kit Part #350E2 .
Old 06-08-2011, 06:12 AM
Normally, the electronic speedo comes with the pulse generator you need to operate it. They screw right into the cable drive unit and you run the wiring.
Trees
Old 06-08-2011, 06:26 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the reluctor wheel will fit the t-350 output shaft. I wonder if the BOP tail will properly space the sensor? I have not tried that fitment.
Old 06-10-2011, 05:53 AM
day day is offline
yup they have what i need. alittle pricey but hey i gotta have it . thx for the info
Old 06-10-2011, 06:57 AM
SSedan64's Avatar
May find something like this also http://www.casperselectronics.com/st...roducts_id=635
just need on with 40-pulse output.
Old 06-10-2011, 07:29 AM
day day is offline
thanks for the new info there SS. i just got off the phone with them and they have everything i need for around 165 bucks.
Coax TV cable compatable with power cable HotRodMan Off-Topic 3 02-04-2011 12:39 PM
Convert Electronic Q-Jet to Non-Electronic cobalt327 Engine 13 10-31-2009 11:22 PM
Swap from Electronic QJet to Non-Electronic QJet 86C10Clyde Engine 9 06-02-2009 07:07 PM
Electronic to cable speedo gmctruckss Transmission - Rearend 1 07-28-2006 08:45 PM
Throttle Control..Cable / Lever & Rod/ Or Electronic ( Throttle By Wire) Viet Nam Vette Engine 4 06-13-2005 04:29 PM
