-   -   Caddie swaps (http://www.hotrodders.com/forum/caddie-swaps-35702.html)
53fordguy 03-09-2004 05:44 PM
Caddie swaps
how well will eldorado and seville parts swap? same year 86'
Rubberman2003 03-11-2004 07:49 PM
I think they will swap just fine, I THINK
FASTCHEVY 03-11-2004 09:41 PM
What are you messin with now fordguy?
astroracer 03-12-2004 05:19 AM
What parts are you swapping? Engine? Tranny? Body?
I've been using online parts suppliers to "research" swapable parts for my Astro van project.
1) Look up the part you want to swap, get a part number then
2) look up the car you want to swap "from" and check the part numbers...
Did you guys know the Astro Vans use nearly the identical front suspension as the '77-'96 "B" body Caprices, Parisiennes, Olds,Cadillacs and Buicks? Front spindles, rotors, calipers, bushings, bearings, ball studs..... All the same.
Mark
