Caddie swaps - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2004, 05:44 PM
53fordguy's Avatar
Junkyard Kustoms
Last journal entry: update after a long time
Caddie swaps
how well will eldorado and seville parts swap? same year 86'
53 fords rule!
Old 03-11-2004, 07:49 PM
Rubberman2003's Avatar
I think they will swap just fine, I THINK
Old 03-11-2004, 09:41 PM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
What are you messin with now fordguy?
Old 03-12-2004, 05:19 AM
astroracer's Avatar
What parts are you swapping? Engine? Tranny? Body?
I've been using online parts suppliers to "research" swapable parts for my Astro van project.
1) Look up the part you want to swap, get a part number then
2) look up the car you want to swap "from" and check the part numbers...
Did you guys know the Astro Vans use nearly the identical front suspension as the '77-'96 "B" body Caprices, Parisiennes, Olds,Cadillacs and Buicks? Front spindles, rotors, calipers, bushings, bearings, ball studs..... All the same.
Mark
