caddy 472 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2002, 07:15 PM
Post caddy 472
Does anyone know were I can run my numbers of my block to find out what year my 472 is?
Old 05-26-2002, 04:56 AM
Tom Tom is offline
Post
go to www.500cid.com scroll down to explore then click on message boards someone there will tell you anything you want to know about caddys
Old 06-06-2002, 07:32 AM
Post
Or you can try www.cad500parts.com Lots info and Performance Parts!
Old 06-06-2002, 10:56 AM
bullheimer's Avatar
NEVER use credit cards!
Post
i know this is coming so just fyi: what the 500cid site owner said in may's hrm: 5 best bolt ons for a caddy: aluminum intake he named a performer good for instant 20 hp; 750 cfm carb make didn't matter, w/dropped base air cleaner; true dual exhaust; MTS steel tube headers as only source for same; hotter cam and spring package from comp or erson or mts limited to less than .550 lift and 235 duration to keep revs below 5200 to save stock crank etc; MTS shaft mount rocker assembly for over 5K rpm; and MTS forged steel rods-$625 i think he likes MTS bye bye
