Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - caddy 472 oil pan
Old 10-26-2012, 07:08 AM
327NUT's Avatar
327NUT 327NUT is offline
There are 3 Cadillac pans, the stock front sump, the El Dorado rear sump which is fairly rare, very deep and expensive and then the route I took. The 425 Cadillac mid sump which is more to the rear than mid will fit just fine, looks a lot better and has the same bolt pattern as the 472/500. You will also need the 425 oil pump pick up tube. These pans are pretty easy to find and don't cost too much. If it's going on a 500 you may need to GENTLY clearance the pan at the 2 front crank throws due to the extra stroke. Here's acouple of pics of mine if I can find a decent one. OOOPS, sorry bout that, the second pic had been resized and screwed it up. If you go to www.500cid.com and join the forum you can get loads of info from big block Cadillac guys and probably find the pan you're looking for....good luck
ID:	68613   Click image for larger version
