Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - caddy 472 oil pan
Old 10-26-2012, 01:53 PM
327NUT's Avatar
327NUT 327NUT is offline
I've never tried one but I hear it will fit, you may have to do a little re-work to the pick up tube. The 368 and 472 has the same stroke so there shouldn't be and pan/crank throw clearance problems. Also I see someone has an Eldo pan for sale, just FYI, the Eldo pan has something like a 9" deep sump....ground clearance may be an issue.
The Following User Says Thank You to 327NUT For This Useful Post:
fordss (10-27-2012)
