caddy 472 oil pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2012, 11:37 PM
caddy 472 oil pan
What oil pans will fit it that are rear sub thanks
Old 10-26-2012, 04:04 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Try cad 500.com and see if they have one..other than that you will need to build one yourself..
Sam
Old 10-26-2012, 05:58 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Good advice about checking at cad 500.com. The Eldo front wheel drive rear sump pans are most often mentioned, but an aftermarket pan can be a better choice.
More Caddy info here.
The Following User Says Thank You to cobalt327 For This Useful Post:
fordss (10-26-2012)
Old 10-26-2012, 06:08 AM
327NUT's Avatar
There are 3 Cadillac pans, the stock front sump, the El Dorado rear sump which is fairly rare, very deep and expensive and then the route I took. The 425 Cadillac mid sump which is more to the rear than mid will fit just fine, looks a lot better and has the same bolt pattern as the 472/500. You will also need the 425 oil pump pick up tube. These pans are pretty easy to find and don't cost too much. If it's going on a 500 you may need to GENTLY clearance the pan at the 2 front crank throws due to the extra stroke. Here's acouple of pics of mine if I can find a decent one. OOOPS, sorry bout that, the second pic had been resized and screwed it up. If you go to www.500cid.com and join the forum you can get loads of info from big block Cadillac guys and probably find the pan you're looking for....good luck
ID:	68613   Click image for larger version
Old 10-26-2012, 06:10 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Same deal w/the Eldo pan- it requires its own pick up tube and attachment stud set up. Get it all if you find a donor.
327NUT those valve covers are really nice!
fordss (10-26-2012)
Old 10-26-2012, 11:10 AM
Cad oil pan
I have a Eldo rear sump pan and pick up tube for sale. pm me.
The Following User Says Thank You to dannronn For This Useful Post:
fordss (10-26-2012)
Old 10-26-2012, 12:03 PM
Has any one tryed to put the 368 1980s oil pan on a 472 or is no fuc*ing way lol
Old 10-26-2012, 01:53 PM
327NUT's Avatar
I've never tried one but I hear it will fit, you may have to do a little re-work to the pick up tube. The 368 and 472 has the same stroke so there shouldn't be and pan/crank throw clearance problems. Also I see someone has an Eldo pan for sale, just FYI, the Eldo pan has something like a 9" deep sump....ground clearance may be an issue.
The Following User Says Thank You to 327NUT For This Useful Post:
fordss (10-27-2012)
Caddy 472 valve spring Question? Studebaker Engine 2 03-20-2011 09:43 PM
Caddy 472 with 10.1 pump gas dadsgp Engine 2 03-28-2006 01:12 PM
472 caddy in a 28 essex????? new_rat_rodder Engine 2 03-08-2006 01:50 PM
472 Caddy into 59 Impala 472impala Hotrodding Basics 9 11-15-2005 10:40 PM
caddy 472 Bohnseye Engine 3 06-06-2002 10:56 AM
