Caddy 500 engine with Turbo Twin Kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2005, 01:00 PM
1300
Comrades, With what system this engine can work most effectively?
Old 02-15-2005, 02:34 PM
BOBCRMAN@aol.com's Avatar
GO to www.500cid.com or http://cad500parts.com
Old 02-15-2005, 03:15 PM
1300
And how much horsepower we can get from this engine w/ twin turbo, high-performance parts, blueprinted block, high-flow headers et cetera?
Old 02-15-2005, 11:31 PM
Last journal entry: Some pics
Just a good put together naturally aspirated engine can put out 400 horsepower and well over 500 foot pounds of torque. Nothing special.
Old 02-16-2005, 08:17 AM
1300
I post this thread to gain knowledge about updated engine, not stock.
Old 02-16-2005, 05:58 PM
well the answer is it depends. how much boost you can run, how efficient intercoolers are, lots of stuff. The well put together engine is a starting point then look at the other stuff.
Ask on the other boards that were posted.
Old 02-26-2005, 05:10 AM
willowbilly3's Avatar
Last journal entry: Body mods
HP= $$ How much do you have?? While I do like the idea of the 500 caddy and plan to use one myself, they are more of an inexpensive way to get lots of cubic inches and torque than a paltform to build an exotic engine from.
And usually turbo engines do not use headers since the plumbing gets real crazy to get a single pipe from the collecter back up to the turbo. You might do something with a set of block hugger shortys. Follow basic turbo building guidlines. The less static compression the engine is built with, the more boost you can run. O-ring the heads. Cam choice for the caddy might be a little tough, I don't think anyone has a grind that was engineered for a turbo engine but there might be some that work.
Maybe put your question up at this forum;
http://www.cowboyseven.us/forum/index.php
