Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Caddy build??
Thread: Caddy build??
Old 10-25-2012, 01:26 AM
327NUT's Avatar
327NUT 327NUT is offline
I have no clue which spring is in there, I'll have to wait till I get it on the road to see how the secondaries come in, which won't be very often. The dyno showed 10" of vac. @ 850 rpm and 14" @ 2000. Should work my power brakes just fine. The car will only weigh about 2800 lbs, has 4 piston Wilwood's on the front and Explorer disc's on the rear.
