Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Caddy build??
Thread: Caddy build??
Old 10-25-2012, 01:51 AM
chevy302builder18's Avatar
chevy302builder18 chevy302builder18 is offline
mr mighty mouse
Last journal entry: shes dropped!!
Originally Posted by 327NUT View Post
Take into consideration that this engine was built for reliabilty and decent street manners in a glass '32 Ford Victoria....hence keeping it at 8.7 compression so it can run on 87 if need be. We ran 89 during the dyno pulls and it purred like a TIGER.
The carb is a stock 780 Quick Fuel Technologies elec. choke/vac. secs. that came with 72/84 jets. After a couple of pulls we found it to be a little fat so we installed 70/82 jets and it ran better, still a wee bit fat but thats ok, don't want to lean it out too much. the timing started at a recommended 36 deg. but we ended up with peak power at 30 degs. and it started a lot easier.
As far as money to build it, I could have gotten away a lot cheaper with stock rods, valve train and an Edelbrock 2115 intake.....but if I wanted to twist it a bit I needed better parts. The shaft mounted roller rockers were $475, the intake was $450 and the new PEP forged rods w/ ARP cap screw bolts were a deal at $220 but I ground and polished the beams and even being that they were new I still had them mag'd, rebuilt and shot peened for $ I know they will be plenty strong. All together I have about $6700 in the engine including the orig. cost. For the kind of reliable low rpm power it developes I think it's very reasonable price to pay....and it's not a crate motor, I built it myself, VERY satisfying.
Here's a few pics during the build and then resting comfortably back in the chassis after the dyno session.
Nice and flat like a table is something i wish i could build. if i had that oppurtunity, id forget about the sbc! maybe one day i will. nice color, that white block is unique, makes it stand out as clean and developed as to a virgin hotrodders eyes. Could you let me see the link to your ford victoria build?
