Caddy build??
There was a time when guys where using the 500 ci Caddy engines.It is a easy 600lbs of torque,but really couldn't rev much above 4,000 rpm without spending serious money on the heads/valve train.
Popular American V8 Engine Dimensions ************************************************** ************ http://i172.photobucket.com/albums/w..._mpiCustom.jpg |
Some guys took the 10 : 1 472's and 500 and just put them into smaller body cars without and internal mod's.
3 Attachment(s)
I wouldn't say "easy 600", some folks take advertised hp and torque claims waaaaay too literally. The factory ratings for the 68-70 472/500 were 375-400 hp and 525-550 torque when in fact most Cadillac performance experts will tell you that these ratings were grosley overrated.
I just dyno'd my BUILT 507" Cadillac, forged rods w/ ARP cap screw bolts, ported large valve heads...but still 8.7:1 comp., 230/238 dur. 540 lift cam, single plain intake/780 QFT carb, shaft mounted roller rockers....blah blah. It made 535 ft. lbs @ 4300 and 466 hp @ 5000. I was very pleased with the results for the 8.7 comp. ratio and it made huge amounts of torque right off idle. Here's a few pics, the red line on chart is the torque curve....which really doesn't curve:D |
Being cut from a different cloth myself I really admire the caddilac stump busters,,,I know there is a big bug eye'd price to pay $$$ vs BBC but who's counting?
327 what did your engine like (dyno wise) for carb & at what jetting etc worked best? |
4 Attachment(s)
Take into consideration that this engine was built for reliabilty and decent street manners in a glass '32 Ford Victoria....hence keeping it at 8.7 compression so it can run on 87 if need be. We ran 89 during the dyno pulls and it purred like a TIGER.
The carb is a stock 780 Quick Fuel Technologies elec. choke/vac. secs. that came with 72/84 jets. After a couple of pulls we found it to be a little fat so we installed 70/82 jets and it ran better, still a wee bit fat but thats ok, don't want to lean it out too much. the timing started at a recommended 36 deg. but we ended up with peak power at 30 degs. and it started a lot easier. As far as money to build it, I could have gotten away a lot cheaper with stock rods, valve train and an Edelbrock 2115 intake.....but if I wanted to twist it a bit I needed better parts. The shaft mounted roller rockers were $475, the intake was $450 and the new PEP forged rods w/ ARP cap screw bolts were a deal at $220 but I ground and polished the beams and even being that they were new I still had them mag'd, rebuilt and shot peened for $125....now I know they will be plenty strong. All together I have about $6700 in the engine including the orig. cost. For the kind of reliable low rpm power it developes I think it's very reasonable price to pay....and it's not a crate motor, I built it myself, VERY satisfying. Here's a few pics during the build and then resting comfortably back in the chassis after the dyno session. |
Nice, what spring in the vac secondary? is the thing pulling good vacuum at around 2500 steady rpm?
I have no clue which spring is in there, I'll have to wait till I get it on the road to see how the secondaries come in, which won't be very often. The dyno showed 10" of vac. @ 850 rpm and 14" @ 2000. Should work my power brakes just fine. The car will only weigh about 2800 lbs, has 4 piston Wilwood's on the front and Explorer disc's on the rear.
nice...
no need for 4:11's with that torque we put one in a poor mid 80's olds with 2:14 rear gears.. talk about top end.. |
UHHHH it's not white, the color is called Cummins Beige, actually light tan. I've got 2 extra sets of 9" gears, a 2.75 and a 3.00 which I think I will use first. With the th400 and a 29.5" tire the calculator shows the rpm of 2433 @ 70 mph, the 2.75's would be 2200. Some of the Cadillac forum "experts" think the engine would be happy at the 2433 mark. Hard to tell, I really think it would pull the 2.75's in this light car just fine.
WOW!!! now that was the ultimate attaboy....thanks 1Gary. I'm sure I will have mooocho enjoyment driving this hot rod.
caddy torque
I have a stock 472 on my saw mill, A friends Dad always ran caddy engines on his Mills , and said the best low cost engine for cutting logs, won't bog when you hit a hard spot in hardwood logs. It did get a good workout when cutting some big western junipers a couple years ago.
| All times are GMT -6. The time now is 02:14 AM. |
