Caddy engine question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2004, 05:35 PM
Ivegonebuggy's Avatar
Can anyone tell me when cadilac put out its first front wheel drive v8?
Thanks
Old 10-18-2004, 07:21 PM
5.0 freak's Avatar
I know that in 1915 cadallic intorduced it's first water cooled V8. I'm not sure if it was on a front wheel drive tho.
Old 10-19-2004, 06:59 AM
Last journal entry: Some pics
I believe around 68. The eldorado switched to front wheel drive. I am not aware of any FWD caddies before that, but I don't know all I could about caddies.
Old 10-20-2004, 05:32 PM
Hey , thanks alot. I am looking for a front wheel drive V-8 to use as the heart of my dune buggy, but I dont want to spend huge $cha ching$ on a 32 valve northstar off of a newer caddy. Plus the fuel injection system is a huge pain in the ***. But I want some crazy dune buggy action and I figured a V-8 is the best way to go.
Thanks again.
Old 10-20-2004, 05:54 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
You would be better off looking for a transaxle out of an Olds Toronado or a Buick Regal...cheaper.
Your real problem will be trying to cool it in a dune buggy.
If you want the system rear mounted...good luck getting by cheap.
