Caddy Northstar - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2008, 08:56 PM
Caddy Northstar
'97 DeVille, Northstar engine.
Anybody ever changed the thermostat in one?
Where are they and how hard are they to get at?
Thanks.
Old 06-19-2008, 10:17 PM
Thanks.
It's on the lower front of the drivers side in these FWD installations. It is inside the waterpump housing cover, which can't be seen 'cause it's under the airbox. It, the intake air pipe, and bottom radiator hose have to be removed to expose the housing cover.
This engine will have DexCool in the cooling system. While many parts stores sell other stuff they claim will mix with it, DON'T. Get fresh DexCool for the refill. This stuff turns bad if slightly contaminated with anything it seems. The other problem will be burping the system, you've got to be patient and get the air all out or the DexCool will go bad on you. If it goes bad it eats anything that looks like aluminum till it's oozing out everywhere, I kid you not!
Bogie
Old 06-19-2008, 10:24 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi oldbogie,
Can the DexCol be drained & flushed
& then refilled with regular anti freeze?
Rich
Old 06-19-2008, 10:29 PM
Originally Posted by richard stewart 3rd
Hi oldbogie,
& refiled with regular anti freeze?
Rich
Yes if you get it all out.
Bogie
Old 06-19-2008, 10:38 PM
XXXXXX
nevermind
90 Caddy steering column wiring. lakota Electrical 4 03-05-2007 07:45 PM
insane 89 caddy from hell... gothrod87 Engine 7 02-13-2007 09:50 PM
Caddy Brake Fun & Does Line Size Matter? Help Needed. bigfred1958 Suspension - Brakes - Steering 5 04-06-2006 09:20 AM
'58 caddy engine bigwoodbass66 Engine 1 12-29-2005 04:38 PM
500 Caddy in a Monte. HemmiGremmie Hotrodders' Lounge 7 12-04-2002 03:53 PM
