caddy rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2007, 08:12 PM
scoundrel57's Avatar
caddy rear
maybe someone can let me know if the rearend mounting is the same on an 81 coupe deville as an impala or like car of the same era. am looking to upgrade to a 12 bolt posi as the engine will be far from stock.would also like to find info on converting to 4 wheel discs.thanks
Old 07-15-2007, 02:42 PM
about the best way to tell is to get measurments off your caddy then measure
the impala
Old 07-15-2007, 08:53 PM
caddy rear
thanks for the response.i was just hoping to be able to use that as a reference point when talking to the folks at strange or wherever i wind up going,because when you tell people cadillac they often times look at you a little weird
Old 07-18-2007, 09:16 PM
yeah,tell me about it
Old 07-18-2007, 11:42 PM
www.car-part.com shows nothing but '77-'83 Cadillac listings as replacements for an '81 DeVille.
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
Tubbing rear with original frame rails? chieftain Suspension - Brakes - Steering 1 04-25-2007 08:02 PM
Rear End ID Riverman Transmission - Rearend 1 08-01-2005 07:21 AM
63 biscayne rear differential problems biscuit63 Transmission - Rearend 8 07-29-2005 04:37 PM
500 Caddy in a Monte. HemmiGremmie Hotrodders' Lounge 7 12-04-2002 02:53 PM
