Cadilac rolling clip - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2013, 08:38 PM
I have a 2005 cadillac sts rolling front suspension w/ wheels, northstar v8, engine computer, fuse box, steering wheel, transmission, drive shaft, complete rolling rear suspension, gas lines, brake lines, gas tank.... Basically everything I would need to build a car...
My question is has anyone build a hot rod using this type of stuff, and if so did you build a frame, or use one like from a s-10. The cadillac suspension bolts to the body w like 6 bolts as does the rear suspension... would you drill holes in the frame to be able to bolt it up that way?
I also have a v6 w/ same setup.. Any suggestions?
Old 06-13-2013, 08:52 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
If I was using all of these components for a rod, I'd probably find a good body and figure out what my wheelbase would be. Then I would build the center frame out of tubular steel connecting the front and rear subframes together to the desired wheelbase length, and get a drive shaft cut to match. Personally I'd rather weld the subframes to the new center frame assembly than bolt.
That's only factoring it in at a 2 dimensional scale. In reality you'll also have to combat track width, frame width, suspension travel and how you're going to modify the body to fit the frame. It'd probably be a heck of a lot easier to start with a good rolling chassis and just make the minor modifications to swap in the engine and trans.
What are you planning on building?
Old 06-13-2013, 09:50 PM
Banned
cool find on the parts! but they have not been put together ever . s10, any truck, car or van frame should work. you will have to fab up a lot . what body are you using ? any pics of the parts. you can sell them in the classifieds section .
Old 06-13-2013, 10:02 PM
Banned
also check this forum out .
Cadillac forums : Cadillac Owners Forum
Old 06-20-2013, 04:04 PM
Thanks
Been doing a little research and ran across a 1940 ford 2dr deluxe coupe that has the same wheel base with two tenths of an inch of the cadillac... Still doing research..
I know I could outfit a pushbutton start, but not sure about the dash,,, everything on the cadillac is digital, so would have to fab something to put in electronics into dash...
Just was kind of curious,,,, I've been rebuilding Cadillac STS car's and have quite a few left over parts.
Gonna hafta sell something before I can buy the project car.
Thanks again.
Old 06-20-2013, 06:08 PM
Banned
you sound like the caddy sts guy. you should be able to work that part out. 2/10ths of an inch is a perfect match! What is the problem.
Old 06-20-2013, 06:53 PM
No problems
Been in the middle of clipping a 07 sts and my day job... Sorry it's been a week since I posted...
I posted originally just wondering if anyone else w/ a little more experience had done something like this.
I'm painting the sts this week and when I sell it gonna give it a shot.
Thanks again, and it may be awhile, but when i get it going I'll post some pics.
Old 06-20-2013, 07:39 PM
Banned
no one has done this!! good luck ! i gave you the caddy site for this!! 1966 eldorado owner And one of the top 50 in the world ! have had this prime example almost 20 years now!
Old 06-21-2013, 07:37 AM
Wiki Edits: 27
Body skin swap.
The service manager at a nearby GM dealer ship bought a late model GM front wheel drive car that had both sides totaled and broken glass. Totaled but low miles and still drivable no suspension damage. He used the floor pan with the front seats steering column, all the suspension, firewall, wiring, front inner fender panels and swaped on a 50's studebaker body skin, John Long who now has the 53 chevy convert rebuild here on the forum did a 50 Merc body skin swap on a GM platform a few years ago.
cadilac deville overheating wulf Engine 9 08-26-2009 12:47 PM
Cadilac distributer in sbc? 1bbr60 Electrical 6 04-30-2009 09:37 PM
cadilac northstar engine jeromy pritchard Engine 4 02-13-2006 10:15 AM
Help! info needed on 51 Cadilac? ronb Engine 9 12-24-2005 08:46 PM
Cadilac is at it again... Forkliftguy Hotrodders' Lounge 6 08-18-2003 01:22 AM
