Cadillac 331 Needs A 350 Turbo Trans. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2009, 08:32 AM
I need information on converting a 350 gm transmission to fit a 1953 cad cdv.
right now it has a dynaflow. I can't stand it. Any connections to a machine shop that has done this before?
Old 07-23-2009, 02:37 PM
fast68's Avatar
likes chevy trucks & boobies
adapter plate out of a plate of steel?
doesnt this engine have the BOP and caddy 90 degree bolt pattern ?
if so then lots of th350 would bolt up
Old 07-23-2009, 03:51 PM
caddy trans
The 331 1949 to 1954 has a partial bellhousing cast with the block. so, the trans has to be altered. i heard some shops can cut the bell on the trans and attached an adapter so it will bolt up.
Old 07-23-2009, 04:32 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Try these guys:
http://www.cad500parts.com/catalog/page30.htm
they may have done it..I have used them in the past..
Sam
Old 07-23-2009, 07:40 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I think a company by the name Bendtsen’s produced an adapter for this application at one time. I may be incorrect
A google check produces : www.transmissionadapters.com for this company.
Quality Adapters are NOT cheap
350 Trans Issue, Stalls engine in Reverse mseifried Transmission - Rearend 12 04-14-2009 01:52 PM
350 Turbo Trans greywulf Transmission - Rearend 3 03-29-2005 09:17 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
Turbo 350 to a '94 700R4 or 4L60 classic_chevy_guy Transmission - Rearend 9 01-27-2004 09:32 PM
Turbo 350 Trans in '63 Chev p/u Freedo Transmission - Rearend 1 09-04-2001 07:59 AM
