We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #16
Old 05-11-2007, 02:33 PM
62cadillac 62cadillac is offline
So does anyone know of anything I need to look for with doing the install or have any tips/pointers that might help me get it done?
Old 05-11-2007, 03:23 PM
oldbogie oldbogie is offline
I think we pretty much bashed this idea into few options for you.
The limiting factor is the old Dual Range Hydro-Matic transmission. It only bolts to pre-1964 engines. The new 64 up BOP-C bolt pattern on the block doesn't accept the older bell-housing. The Chevy bolt pattern is different again and while it possible to purchase Chevy/BOP-C adapters; the only source of 64 and up BOP-C or Chevy to Hydro-Matic transmission adapters has long ago dried up.
This limits you to using a pre-64 Caddy engine, there's worse things in life, if you want to retain the DR Hydro-Matic. Or:
1, You get lucky and find an old B&M adapter Chev to DR Hydro-Matic at a swap meet, Hemmings, e-bay, something like those places. Or you stumble into a 64-up adapter for BOP-C which would let you use the more modern Caddy V-8s.
2, You change to a TH-350/400, 700R4/4L60, 4L60E/4L80E gearbox which will let you run any modern GM V8. Once again this is simpler as Chevy to Chevy; but Chevy can be commercially adapted to 64-up BOP-C and some of these came with both bolt patterns.
Lastly you need to realize that the Cad's value to collectors goes way down with any non numbers matching engine and a non-original type transmission. So I guess before breaking the numbers matching stream you have with the 390, it would have to be a basket case before I go down that road.
If you don't care about numbers matching and want to be in a world where parts are available at reasonable prices, my modern response would be a BBC with a TH-400 or if wanting more recent technology, still a BBC with a 4L80E. The latter gear box will give an overdrive 4th combined with a lock up converter for really efficient, slow RPM cruising. Plus it has a really deep low, like your DR Hydro-Matic, to launch this heavy car. If you went for a fuel injected BBC this would be a super set up.
You could do a 350 or even a 383, but from where my experience has been, when you talk a car that's as heavy as a modern 3/4 ton pick up, you'll be happier, longer with the engine and transmission from the 5000 pound truck. It's not that you can't get power out of a SBC, but asking it to that and move 5000 pounds of vehicle really reduces its life span. Besides a 350 just wouldn't have the torque to launch the Caddy, espacailly with a TH-350 transmission. which has almost a ratio higher low gear and no OD. Getting the Caddy launched takes a lot of torque, this really takes some cubic inches from the engine where a long stroke is better at torque on the bottom end where it's needed with this rig; and it takes some steep gears to help get it launched. I think an SBC with a TH-350/700R4/4L60/4L60E is in over their structural head. I' mean they'll do, but it just won't last.
Bogie
Old 05-11-2007, 04:19 PM
willowbilly3's Avatar
willowbilly3 willowbilly3 is offline
Originally Posted by 62cadillac
well my main concern was to find something that anybody can work on for cheap. I've already purchased a 350 Chevy Engine and 350 Turbo Trans to do the swap. I'm not trying to build a Race Car or anything, just a Daily Driver that I can depend on.
If you want something to work on for cheap a 62 Cad might not be it, even with a chevy motor. In my opinion you are just ruining a good old car putting a cheap engine in it. Good running cad engines can be had for cheap. I have had 425/th400s given to me just to haul them off. A caddy deservs a caddy engine.
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Cadillac 390 to Chevy 350 Engine Conversion"
Port or Full time vacuum cool rockin daddy Engine 39 06-04-2009 12:20 AM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Conversion chevy 350 to HEI from Points. rapsag Electrical 5 01-03-2006 05:23 PM
350 chevy engine buildup dran04u Engine 9 06-07-2003 06:39 PM
63 Chevy II Turbo 350 conversion chevyhome Transmission - Rearend 1 05-31-2002 03:03 AM
