Originally Posted by oldbogie
But the only real problem which is simple to fix is the engine to bellhousing bolt pattern. Adapters can be had.
Don't bet on it. The 62 trans uses a different bolt pattern than the later model BOP transmissions. Adapters are NOT readily available.
