Cadillac 425/200-4r question
I am mating a 200-4r to a mild Cad 425 engine. I had to drill the flexplate to fit the torque conveter bolt pattern. And then while bolting things up, I noticed that there was roughly 1/4" to maybe a 3/8" gap between the torque converter and the flexplate. This is when the converter is pushed all the way into the trans. It just seems like this is little excessive and if I pull it all the way back to bolt the TC to the flexplate, I may not have a good engagement with the snout of the TC to the pump. Should I use spacers between the TC and the flexplate or am I worrying about nothing?
Bob |
I'd use spacers, that's quite a bit of gap to pull up. Like you said, it will short you on engagement...
Russ |
| supercharger.... | 73monte | Engine | 16 | 07-24-2010 10:27 AM |
| question about a previouse question | elrod1030 | Engine | 6 | 03-10-2010 07:35 AM |
| Ignotion Set-ups | Native Gearhead | Engine | 8 | 11-29-2003 01:20 PM |
| Hi All I just Joined, Questions Re:454 rebuild | Gay-Shark | Engine | 8 | 11-29-2003 10:25 AM |
| CADILLAC CONVERTER removel?? | Andrew7dg | Engine | 4 | 11-15-2002 07:25 AM |
