Cadillac 4T80E Trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2008, 08:14 PM
Northstar John's Avatar
Hi Guys:
Got an interesting one for you. I'm in the process of building a new car using the Northstar and 4T80E trans. However, I need to turn the engine and trans around 180 degrees so the engine is behind the trans. That means I need to reverse the final drive in the trans so the wheels turn in the right direction. Any ideas on who might be able to do this?
Old 04-08-2008, 09:06 PM
Wiki Edits: 85
Due to the design of the transmission, I don't think you are going to be able to reverse it WITHIN the transmission.
Reversing the rotation of the motor won't work either as the 3 pumps inside the transmission won't work if the rotation is reversed.
That leaves only one ugly option. Reverse both output shafts between the transmission and the wheels.
Old 05-12-2008, 09:02 PM
4t80e trans
Hey the 4t80e has a final drive on the end of the case you could swap it easily if you found a rev drive dif and ring gear.The passenger side of trans comes off like a regular tailhousing inside there is one bolt on a tube take that loose and the tube comes out like a cane be nice on the r&r of this it has to seal twice one on each end and the one is way up in there have to teardown to replace it if torn.then one snap ring on the ring gear for diff. slides out make sure to match the teeth for gear ratio the computer might act up if its wrong,but the theory that your trying is cool i dont think it cares which way it goes !
4t60 Trans Question david hill Transmission - Rearend 1 04-10-2007 08:58 PM
Is a TCI street fighter 350t trans any good?? tiresmoke55 Transmission - Rearend 1 03-28-2007 12:04 AM
Allison Trans deseldr Transmission - Rearend 5 10-19-2003 07:45 PM
Fine Metal in Trans (NEW) bigjoedo Transmission - Rearend 1 08-09-2003 01:23 PM
Fine metal in trans bigjoedo Transmission - Rearend 21 07-27-2003 11:50 PM
