Cadillac brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2006, 06:20 PM
Cadillac brakes
Ive got a strange problem with a '76 Cadillac Eldorado.
The car has the 425cu Cadddy engine and is front wheel drive. The front passenger side brake caliper is dragging. The original factory caliper started dragging one day running down the highway. I replaced it with a reman unit from Carquest. The problem persisted. I figured maybe I was sold a caliper that was poorly remanufactured. The replacement caliper was returned under warranty and I installed a third caliper.
The third caliper also drags. The rotor, by eyesight on a known flat surface, seems to be perfectly straight. Has anyone experienced this problem? I cant seem to understand why two remanufactured calipers would have this problem?
Old 09-22-2006, 06:35 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
You very likely have a rubber brake hose on that side that has collapsed internally.
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
Front disc brakes 50 Cadillac stock spindles badazz55 Suspension - Brakes - Steering 2 11-23-2005 04:20 PM
G body with manual brakes - it works! - pics dh79 Suspension - Brakes - Steering 7 08-27-2005 10:55 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
1950 Cadillac Disk brakes and dropped spindle badazz55 Suspension - Brakes - Steering 8 08-23-2005 04:45 PM
