Cadillac engine build
Just purchased a 62 Chevy II that needs to be completed.
For now, my question is about the engine I want to build for this car, a Cadillac 472. Looking for build advice, hopefully from those who have done it. Already know about MTS. I am looking for a hot street motor in a 2600 lb car, will be running a TH400 tranny and an 8.75 rear. If possible, I would like about 400-425 HP with the monster torque that these Caddy engines are supposed to be capable of. Another question: Can the Cadillac handle a small (100) shot of nitrous with a stock shortblock? |
Hi,
Well if you want 400hp & 500lb ft tq, without doing anything just get a 70 500Ci caddy engine that's the specs for the carbed engine, & if that's not enough there's stroker cranks for 529 & 540Ci. Rich http://www.cadillachighperformance.com/Engines.html Last edited by richard stewart 3rd; 09-03-2008 at 07:19 PM. |
Thanks for the replies.
I dont think room will be an issue because this Chevy II will have a 2x3 frame with either a straight axle or a Pinto front end, no inner fenders. May set the engine back a few inches, not sure. Might have to fab an oil pan. |
Probably have to fab a pan and headers, but it should fit. They fit in S10s, A/G bodies, and many other cars just fine.
They're pretty light, but you're right, they're behemoth size. I put a 500 in a 66 bonneville and it fit beautifully.
That's not a wrong answer but it is very misleading. 1970's were rated in GROSS hp. 72 and up were rated NET. There is no direct mathematical formula for converting GROSS to NET so let's not go there. 1972 and up did have lower compression than 1970 but Steve Magnante noted a few years back in HRM that most will agree that the '72 has just as much POP as a '70. If the HP numbers are not SAE net they don't mean squat |
BTW Bluesman423, you're going to kill yourself with a Caddy in a 2600lb car
| engine build - 451 stroker | Highway | Engine | 8 | 07-17-2008 10:39 AM |
| Build me an engine! (on paper) :p | mgray10 | Engine | 5 | 02-29-2004 04:02 PM |
| anyone can build me an engine? | mitmaks | General Rodding Tech | 3 | 09-08-2003 02:06 PM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
| Cadillac 425 Engine Timing Question | Andysbeta | Engine | 1 | 03-03-2003 08:21 PM |
