cadillac heat-cool seats in '33 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2010, 09:58 PM
I am installing '06 cadillac dts heat-cool seats in '33 chevy. I got the seat motions wired and they work fine. I need advice on wiring the door heat-cool switches to the individual seat. On my family '03 cadillac deville, each seat heat coil has a 10a fuse, each door module is fused with 10a. The door module has power windows, door latch and heat-cool switch. I am only using the heat-cool switch. Can I wire direct to seat without door module or what do I have to do?
Old 12-31-2010, 11:32 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Let's put this in Electrical.
Dan
Old 01-02-2011, 03:56 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
Its not likely that the seats can function without the control module given the adjustable levels of heat output.
I would check out the possibility that a switch could be wired to select between the seat pad and the seat back elements connected in series for the low heat setting and for the high heat setting connecting them in parallel.
Make sure the pad and the back elements are 12 volt and the switch has the capacity for the load.
Experiment with that.
vicrod
Old 01-02-2011, 04:56 PM
poncho62's Avatar
Wiki Edits: 5
Related question...sort of
Was not aware of a cooling feature....How does that work?
Ontario Rodders
Retrofit 2007 Cadillac power seats vlabrams Electrical 2 04-06-2011 06:43 PM
Best way to heat and cool Garage? HotRodMan Garage - Tools 23 09-28-2010 12:26 PM
cadillac vs chevy mpgruhlke Engine 1 12-28-2009 08:49 PM
cadillac cts seats 39plycoupe Interior 8 07-10-2007 01:38 PM
loud snapping/banging during heat and cool cycle cboy Engine 3 07-29-2005 12:05 PM
