cadillac motor swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2006, 06:02 PM
cadillac motor swap
I have a 89 cadillac brougham with a 307 (5.0) will a cadillac350 match up with motor mounts & tranie?
Old 05-29-2006, 06:43 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I am going to suggest that the 307 is an Olds, and the 350 is a Chevy. Unless there is a multi-pattern bellhousing, probably not.
Old 05-29-2006, 06:47 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Well, the 307 olds in the caddy most likely has a 200-4r so its probably a dual pattern tranny, but the chevy 350 has a lot of differences. You'll need to alter fuel lines, wiring, and maybe a couple other things because the accessories are on different sides. Certainly do-able, but by no means an easy drop in.
That D-body was available with the chevy 350, so I might suggest getting all the different parts that way.
365 Cadillac Valve Cover Adaptors freakyheadbanger Engine 12 08-13-2011 08:44 PM
FWD Cadillac Engine RWD Transmission Question Dusty82 Engine 4 03-19-2005 03:39 PM
1954 Cadillac worth? V Bird Introduce Yourself 2 07-03-2004 09:58 AM
1937 Cadillac RAM General Rodding Tech 0 03-13-2004 05:31 PM
1937 cadillac limo RAM General Rodding Tech 0 03-06-2004 08:07 PM
