cadillac northstar 4.6 swap info needed
i was all set to start to build a mild chevy v8 for my 58 coupe deville when it hit me, why not put in a northstar 300hp aluminum v8 with a 700r tranny.
seems simple enough, right? i did a search in the archives and found some info, but would really like to talk to some one who has done it and can list off everything that has to be collected beforehand and then installed. someone who knows the tricks and or has a link to some site that outlines the procedure. discuss....
http://www.chrfab.com/
Or, run over the backside of an XLR (or better yet an XLR-V, what with the blower and all) bad enough total it, then buy the carcass from your insurance company. ![]() Might be a good idea to run over to www.cadillacforums.com and search around for Northstar (aka N* over there) problems with head gaskets, head bolt threads, mid-block gasket leaks, etc., before you shell out a lot of cash. Last edited by jimfulco; 11-17-2008 at 08:04 PM. |
ChrFab.com is really the best place I've found for aftermarket Northstar performance. I'm using a 4.0L N* for my project.
But they're NOT cheap. For what you'd spend on a performance rebuild, you could easily score a 500-600hp turn key crate 383. With just the parts from CHRFab for a full performance rebuild, not including labor, will run in the $5-6K range. Plus, Northstars are REALLY complicated engines, with nearly twice the parts as an LS1. Though, the aforementioned problems were from the factory and are easily remedied by paying more attention to those areas when you rebuild. Only reason I'm using the Northstar is because I already have one...that, and I'm doing a V8 240Z...and I've yet to see a Northstar in a Z. Otherwise, I'd have just picked up a nice long block from elsewhere. |
and the softer, more pourous cast of the pre-00 northstars. (I have a '95 4.0L) There's a reason people use 350's a lot...they're like a big boy's erector set. They're stupid-simple to work on, you can do a LOT with them, and they're vastly more forgiving for someone that might not know as much as they should (like me. haha)But for cooling, I'm already planning on a remote electric setup. Although they don't have them on their site, CHRFab either has a conversion kit, or is working on one. I dunno if they have it for sale yet, but I'll be doing a remote setup either way as the Z's engine bay will be at a premium for space at the firewall with the northstar. You can get a remote electric pump from Jegs, Dedenbear, CSR and others. Another advantage of using a remote electric pump is that you can wire it through an attenuator or voltage controller, put that sucker in the dash, and control your cooling from the drivers seat. Running a little hotter than you'd like at idle or in heavy traffic? Just bump the knob up a bit and increase flow. Also, potentially cooler temps for those 1/4 passes....and maybe even a couple more mpg's.Of course, you'd need the requisite temp gauge as well as a pressure gauge...but you could eliminate the thermostat in the coolant passage and get the above effects. ...of course, not TOO low or the ECM will be in a perpetual warm up mode in these motors. I'm still waiting for my service manuals to arrive before I know what I can and can't do yet. I've got a LOT of learning to do.
BMW Northstar....Me Too!!!!
If you are planning on using a electric water pump, then I would suggest using the AEM computer for engine management as it has 16 extra outputs that can be programed in. Pump speed could be changed to follow engine temp and engine loads to help maintain temp better. This could be vital as I am sure that rad space will be at a minimum too. I will try and keep you posted more as I learn more during my project. Cheers, Gordo. |
N*Star swap
Still got the N*star donor vehicle in the yard; a '94 Eldorado. Was going to transplant the N*star into a 67 Deville ragtop; exhaust, oilpan and waterpump seems to be the biggest issues. I have all the donor ecms; you can reverse the N*Star intake; and I too was looking at Megasquirt as an alternative. As a matter of fact, I'm going to use the spouse's I6, 250 6 cylinder Mustang convertible as a guniea pig for the Megasquirt, swapping the 1 barrel carb for a mid-eighties Ford TBI (she floods the 'Stang all the time). I've picked up a '70 Eldorado 500 ci motor and a 76 Eldorado fuel injected intake manifold to also use Megasquirt if the 'Stang works out. I have an Eldlebrock intake for the 500 ci, however the hood clearance prohibits the 4-inch height increase without hood modification on the Deville; which also rules out using adapter plates and a Ford 460 EFI setup. A radical modification would be to graft the entire N*Star cradle and FWD setup to your project car....lots of work, but might be worth it to avoid the x-shaped frame on a '58 Caddi (if I remember properly).
for some North star swap forums ya might check out a fiero forum. I have heard a couple people talk about dropping them in one. Although those would be front wheel drive versions.
megasquirt ????
I looked at the Megasquirt site......that looks like a tonne of extra work. The northstar engine already has everything to needs to run really strong,it's just that it's ecm wants to talk to every sensor and all the other seven computers on the vehicle. That is what would keep it from running right (in closed loop). Take a look at the AEM ones. They com ready to go ...plug and play. Then you can go in and adjust the program to what you want,without have to know any trig algorythms, plus it has up to 16 extra outputs for boost control,NOS ,or anything you need. It costs more but it would mean way less time in set-up and soldering. Cheers Gordo. |
northstar waterpump
Ok, I am now joining the electric water pump camp. I spent the day planing the mounting of all the accessories,and there truly is no space for the water pump up front. With the Alt. on the right and the p/s pump on the left and the tensioner mounted up top,under the throttle it will look nice and clean,uncluttered. The electric water pump will have to mount back on the subframe near the strut tower. This way the computer can control the pump speed as needed, as well as the fans.
Does anyone out there know a source for trans adapter bell housing for Getrag trans? There are lots of sources that I have found for all American stuff, but i plan to use my BMW trans and rear end. This was a 146 mph car with a 2.8L straight six that produced only 190hp, I shudder to think what it will be capable of with 300hp and 300ft/lbs from an engine that weighs 65lbs less. Gordo. |
| 67 gto disk brake conversion info needed | firechicken383 | Suspension - Brakes - Steering | 2 | 05-15-2008 05:08 PM |
| Any and all info on resto 56 corvette needed | evilone | Body - Exterior | 3 | 04-30-2008 01:18 PM |
| Chevy engine swap info needed | ChevyJim | Engine | 2 | 12-31-2007 03:33 AM |
| any info on installing northstar eng, into anything otherthan caddys.please help | ralphcrogersjr | Engine | 7 | 11-28-2006 03:37 PM |
| 1948 plymouth inline flathead 6 cyl info needed | 1948PlymouthSpecDel | Engine | 7 | 12-31-2002 08:43 AM |
