Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cadillac Restoration Question
Old 05-22-2008, 07:49 PM
matt167 matt167 is offline
Wiki Edits: 31
Those changes will increase the value to the common person. only if you were going in for a concourse restoration, would it matter that the drum brakes were not there.. if you didn't have original type plug wires, that could cut the value if you wanted a restoration but your radio will sound better.
